- Nov 21, 2015
Mario Turcot said:Chris Perren said:[member=61691]TSO_Products[/member] - Looking forward to using BigFoot. Thanks for making it compatible with both the DF-500 AND the XL. Keeps us updated.
Chris
I concur, having an accessory fitting both DF is a huge benefit. Not only monetary but for shop space.... I hate having several jigs that does the same thing [wink]
[member=62097]Mario[/member] - exactly: that's why TSO is so focused on SYSTEM DESIGN.
Our Clamping Angles work with the MTR-18 Triangle in setting up case work. The hole pattern in the Triangle matches that of the GRS-16 and the Clamping Angle then becomes a reference edge extension for cutting bull nosed stock and similar situations. Now that same hole pattern is designed to receive our new TPG-30 Parallel Guide next month. And we have another item in BETA testing which will fit this same TSO mounting hole pattern.
Hans
