Riving knife not aligned on TS75
RonMiller
I have had a TS75 EQ and love it. However, the riving knife is no longer aligned with the blade. When I cut it holds back and then springs into the gap. Not good. I can't find anywhere to adjust it. I have taken the knife completely out, cleaned it, adjusted it closer to the blade per the 2-4 mm spec but it still wiggles left and right. I don't think it should do that. Any thoughts?
It's gotta be 12 years old or so...still works great except for this wrinkle. Thanks, your idea is worth considering.
If you live in a big enough area, there might be a dealer that does repairs on-site? This "may" be preferrable to the cost of sending it away.
Your info says "Western KY" which is not very specific, which is fine, I get it. But if you are close enough, there is a place in Cincinnati called Edward B Mueller Co. They can probably fix you up.
