Alastaircj
- Sep 25, 2021
Hello,
I use my RO150FEQ purely for polishing cars and gelcoat on boats. Before using the same machine for sanding wood, I wanted to know if there is a known practical issue with using the same machine for polishing paint or gelcoat and then also using it for sanding wood or any other material.
The risk is that I will not be able to clear all the wood dust debrit from the machine before using it for final polishing finishes on car paint or Gelcoat. Any debrit can ruin the paint with swirl marks. Is this a real known issue and practical limitation of the machine or is the machine able to be cleaned internally 100% to prevent debrit being ejected out of the vacuum channels that cannot be reached to be easily cleaned.
I don't want to contaminate a polishing machine for a few woodwork jobs if there is a risk that this is a known issue.
Any advice would be appreciated, because it would be a shame to not use the capabilities of the machine for different purposes.
Kind regards, Alastair...
