Festool from start to finish, except for a hammer and some rags:
More at my personal pages on building the Rocking Horse.
Learned a lot. Won't try to use the 6" jigsaw blade to cut compound curves through two 2x12 fir pieces clamped together again, or if I do I won't use the rocker blade action and will be more careful so that the parts end up the same size, although what I'll probably do is build some patterns and use a bearing bit to get the final size right, rather than 80 grit sandpaper in my 150/5.
