Rolling MFT table with systainer-port and a bit more.
cerv
Working in a one car garage with a MFT table suits my needs.  However, I soon found my self moving it around to accommodate some large or long work pieces or just because I need to get to some stuff out of the garage. So, here is what I came up to be mobile around inside or outside of the garage space plus finding ways to store things.  I did not remove the MFT legs just in case I need it to use the table outside of the garage/ driveway area; plus I have no place to store them as well.
As you can see, I used some of the ideas found here for inspiration.  For that I thank all for it.
[attachthumb=#]
The systainer port I made it one level because I wanted to maximize the space available.  So far I was able to stack in a single column a systainer 3 and 4 with no problem.  The sliders are 24” over-travel so that I can fully clear the bench.
[attachthumb=#]
Because I have a t-lock systainer, the gap in the latch area is smaller than the classic one. I used ¼” dowel,  but it was too loose for the classic sytainer. So, I used these shelf pins and problem is solved by turning them to the flat side against the systainer .
[attachthumb=#]
The mandatory kitchen utensil organizers.  About $2 at Wallmart.
[attachthumb=#]
Using the available space.  Small pull out shelf to store my clamps, stops, etc. I used two cheap center mount slider
[attachthumb=#]
CT 26 vacuum area. I used pvc fitting to store my vacuum pipes.  When I need them, I just reach and pull them out.  Also, I made a poor man’s boom out of pvc as well (see first picture)  it worked really good.  Because I have a 2 ½”  hose from my old shop vac I used it for the boom.  I also had to ground it with some copper tape and bared wire.  So far no more shock.
[attachthumb=#]
TS 55 Saw garage.  I added some material so that the saw does not slide out from the table.
[attachthumb=#]7
Back of the bench. I decided to include a small recess to store my fence, angle unit, parallel guide set, vacuum accessories.
[attachthumb=#]8
For the fence, I just use two screws and simply slide it in the groove.  For the parallel guides I made four brackets out of aluminum.  For the parallel guide extensions, I use the ¼” thread inserts and re-tap them for the 6 mm screw/knobs.  It is a bit in the loose side but still have enough thread engagement for the purpose.
[attachthumb=#]9
[attachthumb=#]10
[attachthumb=#]11
Because I needed some sort of extension when working on a full sheet of plywood I decided to build an extension bench as well.    The internal dimension are the same as the systainer. If I need to make space for more systainer, I only need to add the shelf and the slider.  Right now, it will house my 10” miter saw plus some other tool boxes.
[attachthumb=#]12
Here are the benches connected together.  I used two table locks hardware plus I made some alignment pieces by cutting them at 45 degree bevel.  The alignment pieces are installed at both benches.  I originally intended to include a miter to make a frame but I made a mistake in cutting them too short plus I ran out of material.
[attachthumb=#]13
[attachthumb=#]14
[attachthumb=#]15
[attachthumb=#]16
That's real nice - I love the extension, and the idea of using the 45 degree pieces to make sure it aligns every time is genius!
Well done, sir! [big grin]
That's a very nice cart indeed!
One day, when I have some spare time...
Sweet!
Just got a used MFT3 yesterday (been using the MFT800 on a cabinet with wings and a slider saw holster to make up for relatively narrow cutting surface).  Was wondering how to make the the new cabinet and TADAH!, your shows up.  Great idea on hanging the extras, the side drawer and the extension table.
Hope you don't mind my blatantly copying most of it.  [embarassed] Then again, copying is the sincerest form of flattery...yada yada yada.  [big grin]
Really very nicely done!  Thank you for sharing it.
What a great project, I really like this. Picture 13...really clever design.  Thanks for sharing this.
Cheers,
Rick
I don't see how the MFT is stabilized to the underlying base.  How do you keep it from sliding off ?
I just bought a second MFT/3; realizing I don't need both on legs and this design has me inspired as I also have a small space.
Not at all. I don't mind copying it fully or partial.
Here are some tips that gave me some challenge.  The MFT table is secured by placing 1 x 2" blocks of wood placed in each corner (inside).  To facilitate the placement, remove the top of the MFT table.  I went the hard way after realized the easy way.  :)
Install the alignment "rails" before putting together the benches; that way it is easier to align it.  I taped the "rails" together, sandwiched the sides then I used some brads to secure them before separate the side ends.
Let me know if you need more info.
I screw in some 1 x 2 x 3/4"  blocks inside the corners ( I needed to clear the locking knobs).  If you don't want to keep the legs, the blocks can be taller.
[attachimg=#]
love the cart .
having another cart extend the work surface is a great idea. i live the place for the saw.
this is the most thought out card set up like this i have seen. the only thing i dont see is a place to store extra rails.
Thanks for the complement.  It took me some time to design it,  I put a lot of thought in trying to figure out what works or not in my situation.  I was thinking in design it using Sketch-up but never use it even though I loaded it in my computer.  At the end I used Visio since I am comfortable using it. The down side, I can't do 3D view.  Also the plus I was able to get my cutting layout to maximized the material in hand.  So for this project, I used 4 full sheet (4' x 8') of project plywood (not cabinet grade, but good for the project).
Yes, I originally wanted to store my rails somewhere in the cart.  But I figured that it would be faster to get them from the wall.  The top and bottom are 1410 x 773 mm.  I could make a bracket or something to hold them in the bottom but it require more room to get it out; never mind me trying to get closer to the ground to retrieve them.
Oh by the way, the other benefit for having "extra" deck in the extension cart is that I can rest the my parallel guides when making repetitive narrow cuts.
I was thinking about doing the same thing as you have done, but not as mobile.
How did you decide what height to make it?
I started as with the standard base cabinet height of 36" then I needed to determine the what size of caster I would want to use.  The tricky part would be how many systainer I can fit height-wise in the space.  After some decision to make I ended up close to 37" or 940 mm. By the way I use metric for the design. It made much easier to keep the in check the dimensions.
wow.  if you add a grid pattern of 20mm holes to the top of the extension table you will have 2 mft clamping tables!  awesome design.  I will be copying this one!
That is a good idea.  The only thing that the top is not 100% flat.  At least the top is not glued as the rest of the extension table.  So, if I have the need I can swap it with MDF and have the holes drilled out.
I understand the fixed wheels when they are used individually. How does that work for you when they area together?
  [attachthumb=#]
Cheers,
Steve
Cheers,
Steve
Sorry for the confusion since I forgot to mention the casters details. For the main table, these are 4" total lock swivel casters.  The extension table has two fixed and two swivel caster.  The main table I used the most and with all swivel I can move it around easily around the garage.  When both table are connected I can rotate the tables and the axis of rotation would be in the fixed casters.  One thing to be aware, the table draw latches are not designed to have a lot of pulling loads.  So normally I use a quick clamps just in case if I need to rotate the entire table.  If I would do it again, I would make all swivel in the extension as well.
Thanks for the info.
Cheers,
Steve
