Rotex 150 sanding pad delaminated
Mark37
Recently I bought a new sanding pad for my old Rotex 150.
The glue holding the foam to the hard plastic structure failed.  The foam is undamaged, the glue just failed.
Can anyone suggest an appropriate adhesive to reglue
I don't claim this is a warranty issue, this happened as I was doing some heavy (24 grit) sanding in an awkward position with a less than ideal grip on the tool, and the sander started bouncing.  Before I could kill the switch the pad had come apart.
Thank you
