Router Bit Cleaning Recommendations
WarnerConstCo. said:
I use the blade and bit cleaner from boeshield.
I use this too and sometimes simple green . I just soak bites and blades in it . The nice part is i can reuse it .
I use regular oven cleaner. I tried serval oils, thinners etc. However I got the best results with the oven cleaner. Just spray your bits and saw blades and let it soak in (mine generates foam) for a few minutes, then rinse with water. They look like new afterwards.
-Mark
Household ammonia from the grocery store.  Soak your bits and blades (I use an oil draining pan) outdoors for 10 minutes.  The crud will wipe right off.
Wear gloves, stay up wind.
I found that barkeeper's friend (a powered cleaner sort of like Comet...) worked real good for me cleaning highly pitched router bits.  Worked better than anything else I had on hand at the time.
JT
There was a big stir a couple of years ago that Simple Green (which has an honored place in my shop) may be bad for carbide.  I remember seeing a post from the maker of Simple Green (though I forget which forum it was on) that it could cause carbide to break down if it is soaked for extended periods, though (probably to cover his ass) he did not define "extended period".    As I recall, the consensus was that it would probably be ok to use it to soak blades for half an hour or so and probably not ok to use it for soaking overnight.
Maybe someone out there who is not yet senile can remember more details....
Oven Cleaner - a few years ago Charles Freud of the company of the same name, STRONGLY recommended not using oven cleaner, since it attacked the brazing that holds the carbides onto the bit of blade.
The original simple green was pretty strong stuff - for example, the FAA did not allow it's use on airplanes in any manner.  Then they came out with Simple Green Extreme which, despite the name, was a milder version that did not attack airplanes or woodworking tools.  When I ran out of the Simple Green Extreme concentrate, I found that it had been replaced by "plain" Simple Green.  So unless you have a very old bottle of concentrate, Simple Green is probably okay.  It is one of the options that I use on blades and bits.
