jmbfestool
- Jan 9, 2009
I am thinking of buying
Work Template Set 3
This pack includes:
Corner connection template
MFS-VP 1000
MFS-VP 200
3 bolts
Reversible blade groove cutter HW shank 12 mm HW S12 D14/45 WM
Reversible blade HM-WP 50x5.4x1.1
AND
Routing template MFS 700
For all routers with copying ring, for rectangular (max. 600 x 300 mm) or curved (max diameter 1200 mm) cut outs, 2 angle stops, tilt protection, circle routing insert and operation tool.
AND MAYBE but not sure if it would come in handy alot.
Festool Router Carriage ( Maybe for routing large amount out in the middle where the MFS wont support the router?!??!?!?!?)
I have found a Topic on here about the Work Template Set 3 but its just a link to a website shop and so doesnt help me if this is any good.
I havent seen many people talk about this Worktop template nor has festool made much effort to get it know with curtain promotions. Makes me think is it any good at all. I would like to know if any one owns one of these and is it worth it. I have used loads of normal worktop jigs mainly all the Trend Range with plastic stops and metal stops.( I think Metal are better when I look at the plastic they are often slightly bent out.)
I rather stick with festool because I like festool and also because I am buying the MFS with this kit is it will work together right?!?!? because the Template Set 3 comes with the MFS-VP 1000 and MFS-VP 200 these are the same rails as the MFS kit arent they?!?!? Do you get two 1000 and two 200?!?!? Do you get all the screws and bits and pieces to joing it together to make a separate MFS so in theory I will have a 1000 by 200 MFS and because I bought the MFS 700 with it I will have that one aswell. Is this correct?!?!?
Because all it says is what you can read above so does this kit actually include the router female/male and bolt template cut out?? because it only says it comes with:
MFS-VP 1000
MFS-VP 200
3 bolts
Its going to cost me 600 pounds Incl Vat for the Work Template Set 3 and MFS 700 so I would like to know all about it!! lol As much as possible LOADS AN LOADS!!! Pictures are always best I can easily be confused with words
THANK YOU in Advance!
Work Template Set 3
This pack includes:
MFS-VP 1000
MFS-VP 200
3 bolts
AND
MFS-VP 1000
MFS-VP 200
3 bolts
