john ferri
- Feb 7, 2007
Has anyone used their jigsaw or router to cut aluminum. I'm contemplating modifying a lathe chuck accessory so it fits my lathe. This involves shaving about 3/4 of an inch off the circumference of the jaws--essentially a flat piece of aluminum 10mm thick. Should I:
1. Jigsaw the curve with the appropriate blade and clean it up with the festool aluminum cutter.
2. Do the whole job with the router 3mm at a time (or less).
3. Contemplate buying a bigger lathe with a 12 inch swing.
4. Take back the bowl jaws.
JF
JF
