Ken Nagrod said:Good job, Richard! Looks like that helmet cam is working out well.
Richard Leon said:I used solid pine in the demo. I don't mind plywood for drawer bottoms, but not for drawer sides. It's a one-trick pony of a plane, but it does its job really well. I looked at it for a long time before getting it, but haven't regretted it for a second.
Richard Leon said:William Herrold said:I'm not sure anything was mentioned about one drawer, and the OP has stated he's using a router (1010)Richard Leon said:I'm not an old-school contrarian but for one drawer, I would cut the grooves with my plough plane. From start to finish I would be done in under three minutes with zero chance of making a disastrous error.
Contrast that with the time it takes to set up the router and dust extractor, clamp the wood, do a test cut, and the possibility of making a bad mistake.
Richard.
But now that you've said it.....
PLEASE post a quick vid of your under 90 second dado, with, as you stated: set-up included.
Here you go. 30 seconds to cut the groove. I started cutting at 4.45 in. Before that I introduced the plane, showed how to set up the plane, and other ramblings.
Sure I would reach for the router if I was doing a bunch of drawers, but for one drawer (my bad, I misread the original post) I would reach for the plane. I don't have a preference one way or the other- I just pick the best tool for the job and in this case I'd go with the hand tool.
Groovin' with the Veritas Plow Plane
sancho57 said:Richard Leon said:I used solid pine in the demo. I don't mind plywood for drawer bottoms, but not for drawer sides. It's a one-trick pony of a plane, but it does its job really well. I looked at it for a long time before getting it, but haven't regretted it for a second.
Here in the states we use (well a lot of us do) 1/2" baltic birch ply for drawers. How does tha do hicky work with ply?
Festoolfootstool said:Ken Nagrod said:Good job, Richard! Looks like that helmet cam is working out well.
Ken I think a neck brace should be worn as well to reduce unwanted movement [big grin]
