Looks like there are three pads available.
The 483679 hook loop is the standard pad that comes on a new sander, correct?
Then there are two other pads, the 485647 and the 485648. I suppose these are for use with non-hook loop. Are these required when using non-hook paper clamped on?
Will the RS 2 round or crown boards that it overhangs? Such as narrow rails and stiles? Or can you keep them flat? I can't keep things flat with my ETS 150 even with the hard backer pad. So I have to use my RTS. The little RTS is fabulous for final machine sanding but it's pretty slow trying to clean up the joints on a face frame.
