MrToolJunkie
- Jul 6, 2009
No clip for mine either. So far I do not see the need for one either as my hose fits very tightly to the port.
Scot
Scot
On...the....floor...... [jawdrop] [jawdrop] [jawdrop] Mine didn't come with that either.... [big grin] [big grin] [big grin]PaulMarcel said:Mine came with this clippy:
[eek]
PaulMarcel said:I often use it upside-down in the bench vise to sand small parts. Really fast and easy.
ear3 said:At first glance there doesn't seem to be a difference between surfaces done with the RS2 vs. an RO150 or ETS (EC) 150 -- they both feel smooth to the touch and look even when looking at them overhead. But bring your eye to the level of the sanded surface and look down the edge, and you will be able to see just how much of a difference the RS2 makes.
kcufstoidi said:Its one sander I haven't tried but I also have never had the issue of dishing you mention. On larger surfaces like table tops my pieces are typically all planed to within a couple of thousands of an inch then run through a wide belt using 100P before glue up. I then domino the pieces for alignment. The final sanding is then done with an ETS 150 EC with the hard blue pad on 6 with low suction. Final touch is hand sanding with the grain direction. Using the regular pad and an improper method will compromise a flat surface.
Cheese said:ear3 said:At first glance there doesn't seem to be a difference between surfaces done with the RS2 vs. an RO150 or ETS (EC) 150 -- they both feel smooth to the touch and look even when looking at them overhead. But bring your eye to the level of the sanded surface and look down the edge, and you will be able to see just how much of a difference the RS2 makes.
Just curious Edward, how the swirl patterns compare to each other. Can you see an actual difference in surface quality?
The nice thing is the RS2 has a 33% greater pad area than a 150 mm ETS EC sander and there's only a .5 mm difference in stroke between them.
I use my RS2 to do the yearly refinishing of a teak table outside.
