ChuckS said:Could it be possible to cut the mortises with the CNC off-center that matches one of the preset heights on the DF500's board thickness gauge? In this way, every CNC milled mortise could be duplicated on the mating piece by using the DF500 with its fence set at the same preset height.
A counter-point:Mr Speaker said:That is entirely possible, but the the guy assembling it (=me) needs to remember how to orient each piece and he's not that bright. Even worse, I would have to decide which side needs face in or out before using the DF500. Centering the mortises takes care of the issue and we were invited to give a wish list. On the whole I am very pleased with the Domino. Apart from occasional furniture my use of the Domino is slightly beyond what the manual describes.
Mr Speaker said:Snip. Even worse, I would have to decide which side needs face in or out before using the DF500. Snip.
rmhinden said:I have been reading this thread, what is the actual "rumor" being discussed? Does anyone have a link or something to quote?
Or is the rumor just this thread
Bob
smorgasbord said:mino said:Either way, definitely do not see the space for a "DF600" style product. The XL sells very little and there would be no point in it when there is already an overlap at the 10 mm end of the spectrum.
You may be right that's what Festool does, but I'll argue that trading off the 4mm and 5mm bit sizes to get a 12mm bit and enable deeper mortises on the 10mm and 12mm bits would make the new tool even more popular. I expect competition when patents expire to cover a larger range with a single tool, so Festool might want to counter that.
squall_line said:I think someone mentioned an option to disable the "wag" and make the Domino into a doweler. Alternatively, I just thought to myself, "what if Mafell used the expired patent and turned its Duo-doweller into a Duo-domino?"
With the option to stack them or go side-by-side.
I may or may not be having fever dreams right now and probably shouldn't be allowed near a keyboard... (at least, more than usual).
imdking said:squall_line said:I think someone mentioned an option to disable the "wag" and make the Domino into a doweler. Alternatively, I just thought to myself, "what if Mafell used the expired patent and turned its Duo-doweller into a Duo-domino?"
And by the way, there is no such thing as a DF600!
People just run with off the wall ideas!
ChuckS said:I probably will keep the DF500 if the DF600 doesn't do 4mm and 5mm mortises, but it must have the capability of milling 10mm mortises (100mm long or longer) and preferably 12mm mortises as well.
smorgasbord said:ChuckS said:I probably will keep the DF500 if the DF600 doesn't do 4mm and 5mm mortises, but it must have the capability of milling 10mm mortises (100mm long or longer) and preferably 12mm mortises as well.
Yeah, here's my proposal in graphical format:
Just as with socket sets, if you need the smallest or the largest sizes you'll want those tools, but for many of us, I think my proposal covers what we're most likely to need.
Coen said:Meeeeh. With socket sets lots of people start with a big 1/4" + 1/2" set, only later buying the 3/8" set.
Scott in Bend said:I wish for a Baby Domino XS DF400 that only uses the current 4mm and 5mm tenons. My vision is that it would be more compact and lighter than the DF500.
