Safety Topic
TOH, NYWS, ATOH. are pretty much the origin of "some safety features have been removed for tv".
That video is a good example.  Here Norm says at 0:44.  that when using a router it is always good to have hearing protection and just protection.  Then, 6 seconds later he demonstrates using the router without either.  Then, right after that he said to not wear jewelry of any kind to catch on the tools, then you see him make a cut after that with a ring on. Haha
For anyone who wants a refresher on mitre saw safety:
=175
Since I don't have a SawsStop feature on my Kapex, I use its hold-down clamp most of the time (with a very few exceptions in which cases an F-style clamp may be used instead -- watch video segment at 7:48).
DeformedTree said:
Cut off tools, multi-tools and their big even brother the angle grinder get folks in trouble fast.
Angle grinder - yes, definitely. The other two - just minor injuries, not worth mentioning in this category.
The dremmel type tools do present some danger, mainly as mentioned to the eyes and face.
When set up as a mini grinder or cutter, they expel a lot of dust or fine metal swarf, and even when wearing goggles, the dust can find it’s way into any vents the goggles have.
I know of a few cases of people having fine metal or dust coating their eyes, and has ended in a hospital visit to get cleaned out.
Because the dust is fine, it sticks quite firm sometimes to eyes. Being fine dust, many operators don’t see it, so don’t worry about goggles.
The wire brush fitting for these tools can be lethal, as they’re often poor quality and break up easily, sending metal strands flying around.
I don't know about that. Put one of the circular type blades on a multi tool and you better watch your hand placement. Even with the little plastic edge guard.
My wife is a fantastic cook but has terrible knife skills and has contributed her blood to a few meals. She lets her hands get in the path the knife would take if it slipped or glanced off the object being cut. I have suffered a few wounds from screw drivers, chisels, and pocket knives that slipped and encountered my gnarly hands. Careless, stupid, yes, but common injuries.
I’ve learned to think “what could go wrong here?” before picking up a chisel, knife , turning on a saw etc. I also listen to that little voice that says “this doesn’t feel safe”. I’ve learned to walk away and come up with a safe way to get the job done. I’ve found this little voice is harder to hear when I’m in a hurry and when I’m tired.
I still screw up, but when I do, I add a mental note to my “preflight check list”.
Oh! I forgot to say that when I come up with a safe way to do a difficult operation, especially something I rarely do, I take pictures of the setup.
DeformedTree said:
ChuckM said:
I never use push sticks on my table saw. They don't give the kind of control a push block or push shoe does. Push shoes can be easily shop made (examples can be seen in the school shop image) or bought:
define what the difference between push stick and push shoe is?  I think people use them interchangeably?
Push Stick-Push Shoe
As it says, push stick is a general term for all of these.
The wikipedia article should have been titled Push_Device but it would get a lot less hit  [tongue]
biggest safety tango uniform i ever witnessed was when i told my brother to do a simple crosscut on a bit of 1x2 a year or so ago.
he go it on the mitre saw and lined it up fine.  then he put his left hand by his side, right hand on the handle, blade on the wood, no holdown clamp and fired the old girl up.  i have a sliding one so if this went wrong he would have ended up fairly winded.  thankfully it didin't go wrong but he hasnt been allowed to use the mitre saw again.
just goes to show the saying is true.
dont be scared of the tool or the tool will bite you.
i also think one of the biggest safety violations if beeng scared of it.  a very healty repect by all means but beeing scared is when you get things going wrong becuse you are to busy worrying about what can go wrong so you loose consentration.
i also, in light of what others have said, have notices wandel and john heitz using table saws without riving knifes or blade guardes.
when i get a table saw the riving knife and the guard is staying firmly on the saw, other than when trenching, and if i can, i will use a router for that.
I agree one should not frightened of a tool. But, I think being wary of a tool is smart. When I get antsy about a cut on a table saw or any other tool, I walk away and consider alternatives. I can usually come up with a workaround that doesn’t raise my hackles.
Just an update on using two clamps simultaneously on the Kapex 120.
I have purposely carried on using two clamps whilst cutting long lengths of flat square hardwood only. Mainly because of this thread and what other users have written.
There has been no issues or kick back, even one of my employees has adopted the same method, without issues.
We agreed this should only be tried with completely flat stock.
Ironically, the other day, I needed to trim the lengths on some walnut beads and trims. Some had to be mitred also, so the axillary fences were removed when cutting some angles.
The larger pieces were clamped, and the small pieces held by my left hand.
Near the end of finishing, I had kick back, the usual sickening bang, followed by the hope that the saw isn’t damaged.
I checked the blade guard and surrounding area, and apart from a piece of walnut loose up in the guard, all seemed fine.
I carried on, and noticed the extraction was not as good as usual.
When I finished, I noticed a hole about 8-9mm in the angled dust port. A piece of walnut obviously hit it directly.
I have done a temporary repair with black silicone, whilst waiting for a replacement to arrive.
Although as I mentioned a few times on here, I look after my tools, I don’t baby them but, was quite upset that the saw took a bit of damage but, thankful it wasn’t a lot worse.
So, the next day, it was back to cutting flat hardwood with two clamps, all good.
Make of it what you will 😉
Jiggy Joiner said:
Snip.
If my understanding of your description is correct that you were holding one end with a clamp (on the right) and the other with your hand (on the left), then the risk of kickback happening was similar to that of holding the piece with both clamps on either side of the blade, which is your usual approach.
It is not much different from holding one end of a work (say on the left with a clamp or hand), AND using a fixed stop block on the other end (i.e., on the right side of the blade), a practice that increases the risk of launching pieces across the shop. While it is less common to see both clamps used at the same time, the use of fixed stop block as described above is a "mistake" made by many, including magazines.
We're talking about risk here. Using only one clamp on one side will significantly reduce or eliminate the chances of kickback on the mitre saw.
While on the mitre saws, I came across a DIY kind of video by a couple. He held an angled piece with his bare hand, trying to trim it slightly smaller. Good luck to those DIY-ers who follow their channel, if they aren't aware of the injury risks.
[member=69479]Jiggy Joiner[/member]
            Was this kick back of the saw head or did a small off cut get picked up by the blade?
[member=57948]ChuckM[/member] no Chuck, when I cut the beads, the larger pieces were clamped on the left only.
When cutting the smaller stuff, when the bang occurred, it was secured by my left hand only, no clamp left or right.
I would have used the clamp on the smaller stuff but, some was moulded and the clamp wouldn’t sit right with it. Just bad luck I guess but, again I was fairly tired.
[member=1619]SRSemenza[/member] Too be honest Seth, I’m not 100% sure, as some off-cuts were longer than others.
Could have been a small off-cut fired upwards? I checked the saw again, and luckily nothing else appears to be damaged.
One of my favorite features on the 120 is the ability to slide the fence(s) right up to the blade for that zero clearance cut, and keep those small pieces where you want them
Has anyone come up with a way to clamp small pieces on the Kapex? Pieces that are too short to go under the standard clamp. I just don’t like holding down a piece with my hands.
