Scott-
Short answer, purchased for the project.
Long answer: Bought original lot of material from Target 6/11. Jeff Weiss advised. Original pressure pot spray set from Homestead same time. Jeff Jewitt advised.
In unopened cans for some time. Probably early 2012 first applications. Think I first sprayed the entire project with EM6600, got it black. Probably two coats, used most of a gallon. Then started HSF 5100 filler (tinted black) and worked with that a loooong time. Then on Jeff Weiss's advice hit it with dewaxed shellac for barrier against red oak acid. More 5100, a lot more. Using most of a gallon on just the critical surfaces (top, front, sides, not insides or back and drawer fronts only). Put it on, usually with a brush and scraping excess, then sand it down, off. Not that much build.
Got new materials 7/12, started using HSF 5000 (gray) and spraying it. Ordered fresh EM6600 3/5/13 when ready for color coat - not enough old batch left. Have used almost all of that and most of a gallon of EM6000 clear now.
This is starting to keep me up at night.
Now, that's what I call support! At that level of involvement you can imagine what my state is.
__________________________
Tim:
About stirring:
It's a thought. Could be an issue some of the time when drawing from the pressure pot. Can't see it, out of sight . . .. I let the material sit there, sealed, rather than clean the pot daily. But with the 6600, realizing it separates, I've been pretty good about opening the pot and stirring, not just swishing.
Almost all of the HSF 5100 was applied by brush. Couldn't forget to stir.
Now I have 6000 in the pressure pot and I've been less concerned. When I originally opened the can, after it had been sitting - what, since 7/2011 without much attention, and stirred, I saw little need, and I always thought it was pigments or tints that separated mainly, and with none in it . . .. Anyway, both materials, the stirred 6600 and the less stirred 6000 are acting the same.
I always stir when I go to the original can, and with using the clear disposable cups on the SATA I just swirl/shake it if it's been a while, like a day.
About materials:
It's been mentioned several times that I should move on from the EM6600. Haven't talked to Jeff Weiss yet intend try Mon. Since I need more materials anyway - about out - I'm expecting I'll not continue with Target.
Have already ordered Polys from General Finishes. Tim, that was your last recommendation:
I noticed that General finishes makes a waterborne black polyurethane. I would definitely try that, (test it first) as traditionally that is part of how to achieve a "piano black".
But before that you made another material sound attractive:
I would strip off as much of that 6600 as you can, sand back and then I would seal with a 2 part polyester sealer (ICA makes a post catalyzed water borne sealer, but I have never tried it), it's high build and marketed as low shrink back. This gives you a "level" playing ground and a coating that can handle the sanding. I would level sand the sealer and coat with 2 coats of EM600 tinted with Black Mixol let cure and buff etc. or coat with EM 9000.
Quick look at their site is - well, they're marketing to
me:
Claiming almost "nonexistent" shrink back and:
-Looks like - and stays looking like a mirror
-No more fear with putting down hot cups or wine spills
-Far fewer coats than with conventional materials
-Wet on wet cycles mean fewer sanding steps and faster processes
-the ultimate "piano finish"
-Can be used to build, with polyurethane as a top coat
Q: Forgetting that I already ordered General, would you care to advise between the ICA 2 part and the General product? I might go ICA left to myself.
Finally, you mention tinting the EM 6000 with black mixol. Clears are used for some reason. Depth? They're harder?
If there is no down side to tinting the clear there is, for me, a huge up side. The tint will
cover my pigtails and I'll only have to worry about rubbing out the top layer. That's attractive.
I asked about using EM9000 instead of 6000 when I last ordered from Target, since their site makes 9000 sound like improved 6000. Wound up with the 6000, recall no specifics why. Care to comment on 6000 vs 9000, and would you tint the 9000?
There's still the issue of putting a good hard coating over a soft one. I understand it's a finisher's maxim not to.
