sandpaper labelling
4bocote
[eek] [eek]
Festool:    I have several Festool  tools and use them and love them!!        My complaint:      I can't read the back of the sandpaper to see what is the grit of the sandpaper.    ...  the ink used is a faint green,,..  or sometimes a faint black......  add a little sawdust,..  and it is not visible!!!!!  HELP!!!!  I have to use a magic marker to write the  grit of a sanding disc,..  so I'll be able to use it again..  and the discs are used often.      I have 3 Festool sanders,  only sanders used in my shop,..  please  put a legible marking on the discs that remains visible after the discs are used,..  I keep a 6 month supply of all the sandpaper grits for my sanders  in the shop, as they are constantly used.  Please,,  make my next order of discs marked with a visible ink!!!    thank you,    steve
Same here.
Used to be a bit of pain with abrasive discs all over place, trying to follow a sequence.
Can 'feel' them with finger-tips of course - can get surprisingly good at knowing what's what's.
But...  yep - how about clear markings on them Festool - please.
Richard (UK)
