Michael Kellough
Brice Burrell said:Michael Kellough said:Brice Burrell said:Michael Kellough said:...It isn't difficult to make a shallow scoring cut with the Festool saws without changing the depth of cut. Just find the right way to hold the saw so you can limit the depth for the first pass.
With the blade toed on the Festool saw I'm not sure it's not worth the time and effort for a scoring cut.
The difference between the front teeth and the rear teeth (the toe-in) is only .002" at full plunge.
At scoring depth the toe-in is insignificant. All the other brands of track saw should have similar toe-in for best results.
That said, I rarely need to do it, even with the old ATF 55 saw.
Michael, I don't if the .002" posted is typo or if your old ATF has much less toeing. I believe it's more like .01" to .02". I'm confident you're cutting the veneer twice so that sort of defeats the purpose.
Someone posted a link to Rick's TS55 manual so I checked.
"7. Slide the back of the sawblade up to the edge of the cut piece of wood, except place a piece of paper between the blade and the wood. This paper serves as a shim to space the blade slightly away from the wood at the back of the cut. The saw’s cutting is improved if the back of the blade is skewed slightly away from the guide rail."
A typical piece of paper is around .002" thick. If your toe-in is set around that much when the blade is at full depth then when the blade is only at 2 mm or less there won't be any significant re-cutting at typical material depth.
