- Jan 22, 2007
Jon,
I am updating the procedure in the TS55REQ manual to cover both cases. Even though the previous procedure is geared only toward matching 2 saws, the concept is the same. You would still complete the same procedure, except you would only be using 1 saw.
Because your saw is already significantly out of adjustment, you will likely have to repeat the procedure at least once to get the saw close to alignment before doing a final adjustment. Just make sure that each successive attempt cuts new wood on your test workpiece. Once the saw has made that cut, do not move the guide rail.
Also, the previous manual refers to a sheet of standard paper. This is actually too thin. It should be either folded paper or a thin business card to give you the recommended 0.004" of toe-in spacing. (Most business cards are actually thicker than this.) Also, before publishing the next manual, I will re-confirm that 0.004" is the correct recommendation. That number is quite a few years old, so I want to make sure it is up to date.
