Dave Ronyak
- Jan 23, 2007
I am trying for the first time to use my Whiteside locking drawer glue joint bit, Part Number 3347. According to the meager instructions supplied with the bit, it should be set ~5/16 high. I spend most of yesterday evening trying to get a good, tight fit with poplar drawer side stock ~0.80 inches thick, using Whiteside's brass setup gauge bars to set the nominal bit height, and thereafter trying slightly higher and slightly lower bit height settings hoping to tune the fit of the joint. With this bit, the drawer side pieces are milled standing on edge (long dimension vertical relative to the router table), and the front and back pieces are milled flat on the table. I am certain I am orienting the pieces correctly and holding the side pieces true vertical (extension fence on my JoinTech fence, checked to be true with an 18 inch reference triangle from Woodpecker). Anyone have any idea how close parts machine with one of these bits are supposed to fit prior to glue application? I am thinking of giving up on this bit and going to classical dovetails or domi-tails. The drawer joints I am wanting to make need to be very strong because each drawer is ~24 inches deep by ~34 inches wide and intended to be loaded up to ~200 lbs.
Dave R.
Dave R.
