I've been following the shaper origin's journey to market for a while and now it's finally arrived in europe and I'm in a position to spend a bit of money to get some much needed cnc capabilities in my workshop... I really like the look of the shaper, for how straight forward it seems and for it's lack of footprint in the workshop. My other option is an entry level gantry cnc for a similar price - around £3100.
It seems fairly difficult to get an idea of how successfully people are using the shaper in a professional workshop setting. A lot of the reviews seem to be just explaining how the tool works (because it's neat and interesting in itself), or from where people with a good instagram following who have been 'lent' the origin from shaper for them to try out (and show off) ... What I'd really like is an unbiased opinion of someone using it for professional work and how they are getting on with it. My main interest would be for accurate jig making.
My biggest concern is accuracy, and there seems to be little info on this regarding actual numbers. Shapers website states...
This is really vague - and 1/100th of an inch (0.25mm) isn't so great IMO.. To add to the confusion further popularwoodworking did a review stating with regards to accuracy...
0.001” (0.025mm) is a really good tolerance for any woodworking machine, but they fully contradict this with the numbers they actually report which are pretty poor and don't make too much sense either. So it's hard to get an idea of what to actually expect from the shaper. I'd really like to know what sort of accuracy tolerances I should expect repeatably once i've gotten reasonably good at using the shaper? If anyone has any info or experience here, that'd be really helpful..
Sorry for rambling on but if anyone has got a shaper and uses it professionally (or not) I'd really like to hear how you're getting on generally, but also specifically regarding accuracy..
'With a small amount of practice, you are actually able to achieve cuts far greater than within 1/100th of an inch using Origin. But we’ve decided to state that number as a more generally achievable range to help bound the conversation.'
'In situations with tight tolerances, like joinery where .001” matters, the Origin does quite well. Measured accuracy from 12” to 36” is .02”-.05”, from 4’ to 6’, .08”-.18”. Repeatability — important in real-world CNC use, is about .01”.'
