Shaper Router Bits
Jason.L.Hagen
I'm trying to find a way to order a couple of router bits for my Shaper, but because I live in the US, I can only get the imperial version. But the plans I found called for the metric version. I can't see to find another company that makes these. I'm hoping that someone might have some ideas.
3 mm Up-spiral Router Bithttps://www.shapertools.com/en-gb/store/product/3-mm-up-spiral-router-bit
6 mm Up-Spiral Router Bithttps://www.shapertools.com/en-gb/store/product/6-mm-up-spiral-router-bit
Thanks!
Thanks!
Amana tools sells a 6mm and 3.2mm, although they might not qualify as upspiral. Bitsbits has a 3mm.
https://www.toolstoday.com/v-12758-46585.html
https://bitsbits.com/product/deep-cut-3-0mm-square-end-mill-20mm-cut-length/
Sent from my SM-G986U using Tapatalk
Seems like imperial/metric shouldn’t matter, as long as the bit is small enough to cut the smallest inside diameter of the design?
That is "sort-of" correct. You can definitely adjust for the difference in diameter with off-sets in the in-board software, but you would always have to be aware of and compensating for it. Even when using the "correct" bit that is designed into a set of instructions that someone else wrote, you should probably still be using an off-set in the roughing passes anyway.....so doing that and compensating for an off-size bit too, could work on your head pretty good.
There's a direct diameter setting called Bit Size.  Cut Offset can still be used separately.
https://support.shapertools.com/hc/en-us/articles/115002904774-Bit-Size
