Richard/RMW
 - Jul 11, 2010
I'm going to finally "Parf out" the surface of my MFT/SYS cart but before simply whacking out a field of 20/96mm holes I figured I see what clever schemes were out there.
As background, back in the Rip Dog days (for those who were around then), the primary reason I designed the rail clips with a 20mm offset was to avoid the blade kerf running over a line of holes on the MFT. In hindsight, this was not as big a deal as I thought given the wide acceptance of the Parf dogs (pre-Parf guide availability), nobody else seemed to mind the kerf running across the holes.
The top will be 700 X 1346mm and I have some 3/4 MDO I'm going to use up. I don't actually do a lot of cutting directly on the top these days but that might change, especially if there's a sacrificial portion. As you might imagine, I have pretty much every 20mm dog-ish gadget you can imagine other than the TSO triangle. The operations I want to incorporate into the top are:
So, other than omitting a line of holes or adding a sacrificial strip, what options am I overlooking?
Thanks!
RMW
- VacSys - Someone shared a dog-mounted flat plate in another thread, basically covers the holes to let the unit vacuum clamp itself to the top
 - Assembly fixturing - just landed a set of the UJK pups and their clamping ducks, squares, spacers. This is really what's prompting me to make the new top
 - General clamping with both Festool clamps and clamping elements
 - Cutting, almost exclusively sheet goods
Thanks!
RMW
