I don't use a cambered blade, Mario.
If you do plan to put one on a LA blade, the camber needs to be much bigger (pronounced) than the one used on a high angle blade. (Are you a Tormek user? The Tormek SE77 jig is what you'll need to camber your blades.)
In addition to its use for scrubbing in a regular plane, explore the power of a cambered blade here:https://www.popularwoodworking.com/techniques/learning_curves
