Some of the kits on here look really nice but are overkill. You don’t need that many rolls of gauze. I’m a Nurse and a Paramedic and haven’t used that much gauze unless I was tying someone down with it. Here’s a list off the top of my head:
Bandaids - get an assortment of different kinds, get the stretchy ones.
4x4 gauze pads
Coban self adhering elastic bandage
Hydrogen Peroxide
Betadine
Tweezers - good ones
Antibiotic ointment (Neosporin)
C.A.T Tourniquet - can find them online for about 10 bucks
I saw someone mention super glue. You can close a wound with CA glue but make sure the wound is REALLY CLEAN!!! Let it bleed a little while then rinse with HP and Betadine if you aren’t allergic to iodine. Pinch the cut closed then apply to the exterior skin. But really, you should just put a pressure dressing on it and go to the emergency room.
Bottle of saline solution for eye wash. Again, if you can’t flush it out, go to the ER.
NO burn cream!!! Dry sterile dressing
If you hit your hand or pinch it or burn it, remove any rings on the affected fingers. They will swell and the ring will have to be cut off.
4x4 gauze pads
Hydrogen Peroxide
Betadine
