I am an owner of a small size closet company. I currently use a compound miter saw to cut down 14? wide shelving material and always encounter chipping on the underside once the blade gets slightly dull. I can?t afford a $50K panel saw and believe there is a more efficient way to cut down the shelving. I was wondering if the Festool TS55EQ and MFT could cut the material relatively chip free while not changing the blade every few cuts.
I don?t know if this is a valid assumption but I see one advantage of a 12? saw blade having twice the diameter and therefore last twice as long than a Festool 6? blade.
I need to make repeated cuts ie 6 - 14? shelves at 21? wide. I assume the Festool can do this with the retractable fence stop.
Any advice would greatly be appreciated!
Thank you,
George
Thank you,
George
