I'm somewhere in the middle I guess.....
I don't have as TS, and frankly don't have room for it in my totally stuffed 280 sq.ft. garage....
But I do have a CMS, and the TS55 insert for it. It's a nice piece of kit, and the fact that it's portable is great.
However, there are some downfalls as well.
I hate having to mount the TS55 in the CMS, it involves just too many actions. You have to dismount the riving knife, slot in some odd steel contraption to disable the plungelock, install some kind of plastic hook to keep the triggerswitch depressed, screw on the subframe that takes care of the depth adjustment, mount the saw to the baseplate, and mount the fixed rivingknife-cum-bladeguard.
Mind you: it's all very well designed and I can appreciate the thought that went into designing this, but it just takes too many separate actions. In reality, it doesn't take that long, but it FEELS long, it's not click-and-go so to speek. And when the saw IS in the CMS, I stumble upon the fact that angling the saw is possible, but far from easy. And that's what I basically use the CMS-TS for - to produce off-square profiles on site. I wouldn't even try to do this using the guiderails, even if i owned the parallel guides, which I don't. Once dialed in, the CMS-TS performs admirably, but dialing in the right angle is somewhat error-prone and frankly just takes too d*mn long.
So I have to plan for the actions I can do with the saw on the rail or MFT, vs. the saw in the CMS. A second saw would be nice, but buying a second TS55 would more or less "nullify" the "System". I could opt for the TS75, but then again I'd rahter have the bigger saw in the CMS insert, and the smaller saw on the rail / MFT..... but the bigger saw won't fit my current insert, and although I've pleeded my arse off, the nice combination offer for the CMS-TS55 was not available as a CMS-TS75, even when I offered to purchase an additional separate TS55 - now THAT was a letdown [mad] Financial restraints can be somewhat annoying.... [sad]
All in all it's a mixed blessing. I'd like a TS, but don't have the room to spare. I'd settle for a good quality contractors saw, but I work out of a rather small trailer, not a big van, so space is limited . Then again, the fact that the CMS also takes my OF1010 in the Basis 5A plate, and that the sliding table miter fence serves both masters without complaining, makes it a very useful kit. Fitting the OF1010 is quite straightforward and doesn't feel as awkward as fitting the TS55. I'll definitely buy the insert for my Trion as well, that should even enhance it's usefulness. The "System"definitely works for me, but in case of the CMS-TS, it's the set-up time that kills me.
Just my 2 eurocents worth of food for thought.
Regards,
Job
Regards,
Job
