Show your systainer
My Bosch 10.8/12v ‘sawcollection’ in a Sys 3 Classic
[member=42423]coho10[/member] the last photo where you have the ridgid trimmer is using a Sys 1?
I also had that orientation problem. I'm using an iPhone and disable the flip rotation on it. Since, all my pictures comes in the right orientation.
Mario, It's a sys 2. I wanted to leave a larger base attached, otherwise it would fit in a sys 1.
Thank you! I have the same trimmer and you gave me the idea of have it in a systainer with all the accessories. I actually use the bag that was coming with the router and it became hard to fit everything in it.  [eek]
Mortiser said:
Does someone know if the lids for the Sys-Storage Box will fit the Sys-Toolbox 2 ?
http://www.leevalley.com/us/Festool/page.aspx?p=70732&cat=5,105,71886
The clear lids? Not sure of the physical size would fit , it might,  I have both and can check when I go to the shop. But you would need to come up with some type of hinge / attachment even if they would fit. But that could be worth exploring for added versatility. Though if you really needed larger closed space , a regular Systainer can do that job.
My new :)
It looks doable. But would take some work. A vertical slot needs to be cut in each corner (easy), Some sort of screw or rod added to mount the lid.  The center would still have quite a bit of open space under the handle. I did not take any measurements.
Michael Kellough said:
[member=61651]Bartel[/member]  Your Bosch kit looks great!
The jigsaw seems to be much smaller than I thought, so now it’s tempting. Does it work well? Are the 10.8 and 12 batteries interchangeable?
Thanks, Michael!
Yes, the Bosch GST performs quite well for its size (and price).  Mostly I just use it on site for a quick cut out.
Indeed, the batteries are interchangeable. However, in an older model charger, the 12V 4.0 Ah batterie takes much longer to charge than in a recent model.
Thanks Seth for checking that. I would like to use the toolbox but have a lid to keep the dust (or most of it) out of my hand tools. I may give this a try.
Mortiser said:
I didn't take any measurements and certainty of success is not guaranteed. If you try it post it!
Tooms said:
Not my video but just got the link, that is another way to use systainer
"A little bit of rhythm makes Systainers go round"
https://www.instagram.com/p/BsTUu98FoKd/
Lol that's my fault that one. I know the Insane Dane and while chatting one day I said why didn't he attempt a full size systainer version of that micro sys tank that we had seen.
Being completely mad he loves a challenge and this was the resulting video.
Sadly he's not having a good start to 2019 as just the other week some scumbag broke into his van a stole a big chunk of his Festools :-(
Sent from my WAS-LX1A using Tapatalk
