six-point socket II
- Jun 26, 2016
Advertisement
Hi Neil,
The tester is called „VDV512-101 Coax Explorer 2“ It tests for shorts and continuity. Simply put one of the four remotes on one end of the cable/installation and the tester on the other side. It‘s small, leightweight and easy to use - less bulk than the larger VDV testers and also quicker to use - especially when you don‘t need more functions or it‘s just a small installation like mine. If it‘s a bigger installation, the VDV‘s with up to 19 remotes are a better option.
I love these small gadgets, so when I was asked if I wanted to test it, albeit having the VDV501-825 Scout Pro 2 LT, I said yes
I know that feeling finding something like that Scotch tape in a junction box. In my case this will be OK for a couple of weeks and then these not permitted screw connectors will be replaced with Wago connectors and the wire that is just running through that box will be removed and placed next to the box in it‘s own conduit.
Kind regards,
Oliver
Hi Neil,
Kind regards,
Oliver
