six-point socket's tidbits of Home Improvement, small projects and other stuff.
  • Start date Start date
Status
Not open for further replies.
Snip: “ I can't wait for the next owner meeting. The same question will come up, from 2/3 or more: "Do we really need to repair/maintain this, is it really necessary?", then a vote takes place, and nothing except for bare necessities will be done. (If anything at all.)
This is also the reason there is absolutely no "DIY" on this.”
Oh.. I feel with you; been there, done that. And now it’s part of my day job (but luckily very seldom totally lack of insight, or will to listen to professional advises)
I'm not loosing sleep over this, Stig.
The truth is, I could list our lot/parking space at the local grocery store's blackboard today for anything from 15 to 20k and it would be taken by tomorrow. Only actual cost, transfer of the title at a notary/conveyancer.
And if I gave it a little more time, I could offer it to banks or housing investor/investment companies in the 3 big cities surrounding ours, and make 25 to 30k off it.
There is not much going to change that situation, and once they start working on "our" street in 21 or 22 (complete re-build incl. sewer ...), parking spaces will even be more scarce then they are right now. Which means that number can only go up.
No one would bat an eye at the electrical installation/ water ingress - at least until it has become a real problem. The reason for that is, many of the owners are fairly old and rent out the space. But not with a contract/ rental agreement. They don't declare the "income" ... So they think they don't have to abide by the laws concerning landlords and the corresponding obligations. ...
Kind regards,
Oliver
Hi everyone,
This morning I received shipping confirmation of some of the parts I'm gonna be needing for the basement built-in cabinet. So time to think about how I'm going to drill the 35mm holes for the concealed hinges. I decided against drilling them just by hand, instead I will be using my old drill stand and corresponding drill. (I will be utilizing the Centrotec-Jacobs-Chuck-Adaptor and a Centrotec chuck to use my Centrotec-Zobo drill bits.)
Even earlier than the shipping confirmations, warnings from "Nina" (our German governments warning system/app) came through about an extraordinaire heat (wave) today. So instead of getting a brain freeze from the AC, I decided to go into the basement workshop and clean, maintain and adjust the drill stand.
Here are a couple of pictures from after I had completed the cleaning/overhaul.
Scale is spot on. I will still test drill in a scrap piece first. ;)
Kind regards,
Oliver
“(I will be utilizing the Centrotec-Jacobs-Chuck-Adaptor and a Centrotec chuck to use my Centrotec-Zobo drill bits.)“
[poke]Oliver, why not leave the adapters in the drawer and put the six-sided ZOBO bit directly in the three-jawed AEG chuck?
Seriously, every extra coupling adds a little more runout, and the Centrotec shank is a bit undersized for a 35mm cutter anyway, imo. And you don’t want the hinge hole to be too large.
Probably because you will also use a smaller ZOBO bit for the fasteners? [huh]
Hi Michael,
you hit the nail on the head, although it's not going to be another Zobo bit, but the 5mm CE- carbide bit w/depth stop and probably the CE- hinge drill bit.
I'm not worrying much about runout here, I've used the adapter before - albeit not together with drill stand - but with the same machine, and also another Hilti - and that worked very well. I trust this stuff.
But like I said, I will do some testing for depth setting, so I can always rely on chucking it directly if the CE adaptor gives me trouble. I will keep an eye on that.
I basically don't really like chucking the hex shaft (CE stuff) directly, it's pretty short, then comes the detent - and chucking it deeper - on the round surface is really not ideal.
I agree that the shaft diameter is fairly small for 35mm.
Kind regards,
Oliver
Oh, that AEG drill.. a fantastic piece of equipment, with state of the art electronics - amazing for that time, and in some way still is!
We have that same drill stand at our cabin. Reminds me to “rescue” it before someone else does..
Stig, you're familiar with the system, then? Mid/late seventies iirc. This is the stuff I learned with, under my dad's supervision. And I used them on some of my first projects.
Jigsaw is a separate machine.
There's a separate sanders as well, need to take some pictures when I have the time.
Kind regards,
Oliver
What? Oliver, you have the whole set, still? [emoji15]
[emoji51]
In my parents garage there is the „table saw“ attachment somewhere. But I have never seen it in action...
If you like a challenge, how about using only AEG instead of Festool for the built-in. [emoji12]
Someday you need to host us for an extensive workshop tour of the palace you call your shop. :)
I have that exact jigsaw table but mine is Bosch and I still occasionally use my ancient Bosch 1582 in it.  It's great for fabbing smaller pieces.
I have the same stuff. Also very portable. A Sys2 contains the table, jigsaw, and about a 100 blades with room to spare.
Also have a similar table that’s made for older Metabo jigsaws if anyone has a use for it.
Wow! You have the lot.. almost! [blink]
I remember the jigsaw, but it’s not around anymore. I recognise the table saw attachment, that one also gone. So yes I remember. AEG had (maybe first) similar to Festool CMS system, all high quality.
I used to use that particular drill to polish my cars, my first encounter with constant speed electronics - it was in fact THE only drill I found which was controllable with the constant speed control when polishing at lower speeds. And the sound it makes 😎, it oozes quality.
When I bought my house, I was among many other things left with the AEG sander attachment - I’ll post a pic tomorrow  [wink]
Edit: Pics of the missing Schwing-schleifer:
[attachimg=1] [attachimg=2]
Hi everyone,
[emoji51]
Maybe someday, but in general, I think you'd be pretty underwhelmed after seeing it.
Totally agree, maneuvering small pieces to and around the saw blade is much easier/ nicer to control than vice versa.
Somehow I can't give up the old metal case, I will show it in the next post. :) But if I'd use it frequently, Systainer it would be, definitely!
Yes, quality was incredible for it's time and still is. Wait for next post. ;) But given all the new regulations, all this stuff can't be used commercially anymore. (Sometimes it's good to be a DIY'er ;) )
Kind regards,
Oliver
As promised some more pictures. :)
Orbital sander. Including dust extracting attachment/ shoe type.
The full AEG jig saw kit. Jig saw STSE 350, jig saw table ZT-ST and the yellow metal case.
Kind regards,
Oliver
And now, let's start with the basement build-in cabinet makeover.
Overview:
Concealed hinges:
Hettich Sensys 8645i with internal damping. (110°, TH52. 9073605)
Hettich mounting place System 8099 (D=3mm. 9075082)
Hettich Covers 9088250 & 9088251
This is what it will look like when installed:
Hettich jigs 0000351 (right); 0045150 (left)
Handles. Also Hettich, or so I thought. ...
Quality is not so great, very simply made. The screws that came with the handles are also pretty bad ones. (I fathomed that, so I ordered different ones that should arrive any day.)
I was wondering why I couldn't find these handles on Hettich.com while I was in the process of ordering all the stuff.
This is the reason:
Hettich has a DIY/DIY-market type line of products that can only be accessed through hettich-diy.com aufrufen While products are the same as from the professional line, especially the offered handles vary greatly
When I found these handles listed under "budget" :https://web2.hettich.com/hbh/catalo...=procat_diy&procatTheme=diy&subProjects=false  everything made sense suddenly.
Given they are for the basement, and given what I paid for them - it's OK.
Kind regards,
Oliver
Oliver-Sorry I was slow to reply.  On Aug 6th when we were discussing easydrivers, you asked if I have a 1964 Studebaker Champ, and I just saw that reply.  I had a rather rare one, but not anymore.  I had a 1964 3/4 ton V8-they only made 204 of that type in 64, their last year in business in the  United States. The windshield, doors, fenders and front of the truck were the same as a Studebaker Lark car with just a different grille.  The bed was left-over stampings from Dodge and was too side for the cab. The truck was built like a tank-had 58 leaf springs.  I took the springs apart once and painted them, and still remember just the springs weighed 290 lbs.  It was a great truck, although what I would really would like to have is a 1937 Studebaker Coupe Express. Look that one up to see a truck with style.  I enjoy your comments, Oliver, sorry I did  not respond.
Thanks for your reply Ron. Don't worry about overseeing a post, that happens. I'm glad you still caught it.
That must be some great memories, it's definitely a great truck! I checked out this 1937 Studebaker Coupe Express (https://hymanltd.com/vehicles/5584-1937-studebaker-coupe-express-truck/ ) what can I say ... they don't make them like they used to. Simply amazing. I could see myself driving one. Those fenders, the headlights ... the whole style. Impeccable.
Kind regards,
Oliver
Hi!
Time to post some "before" pictures. You can see that I made a little mistake in my first sketch that I drew just from recollection.
Then I measure everything, starting with the doors. Then removed the doors and some trim, to measure everything else.
Now I'm working on the good sketch/drawing and a cut list.
Kind regards,
Oliver
With some help from my dad, who learned drawing in the beginning of his career, the drawings were made.
Don't worry about the missing kerf on the cut list for the doors, it was just to check if everything fits well within a single board.
Plywood has been ordered, now.
Kind regards,
Oliver
Current state of affairs.
By now, everything that will ultimately be replaced is removed.
Of course no project goes as planned, I will need to expand the tiled floor up to under the radiator now.
I found a treasure:
An old Quartett card game card with a Porsche 912 on it, a crown cap from Hannen brewery:https://de.wikipedia.org/wiki/Hannen-Brauerei (sadly this entry is not available in english), a marble and a Pfennig:https://en.wikipedia.org/wiki/Pfennig .
Tuesday or Wednesday the plywood is going to get delivered, then that work will continue.
Kind regards,
Oliver
Status
