Slatted bathroom bench
John T.
Here is my first project I feel is worth posting here since I got back into woodworking a few years ago.
It's a dupe of this bench, but I used rift sawn oak instead of teak. I was surprised when I priced out teak lumber it was a significant way towards just buying the bench! I went with Domino butt joints instead of finger joints to simplify it, also I don't have a table saw and dado blades. This is my first extensive use of the Domino and it really helped with alignment and glue ups.
It took a lot more planning than I'm used to for the orders of operations of chamfering, glue up, and finishing, since there were so many different inside corners and small gaps. I did some prefinishing before glue up.
I usually use Polyxoil but went with Rubio Monocoat for the first time. 5% white to try and minimize the ambering effect. I like the color, although I wish it had less of a tendency for the pigment to highlight the grain unpredictably. It doesn't feel as smooth as when I use Polyxoil, I guess because the instructions said to only sand up to 120 grit. I may go back and sand the high touch surfaces with 220 grit and reapply Rubio. The Rubio was much easier to finish and with so many tight spots I was glad to only need one application.
Looks good. I'm always looking on DWR, Room & Board, and other furniture sites for inspiration. I've always stuck with 120 for Rubio but have watched videos where people have sanded to 150 and 180. I'll have to do some tests to see the difference.
I like the look of the oak you chose. White oak? Anyhow, nice work! :)
Thanks Anthony! It is white oak.
I really Room & Board stuff too, I would say them and DWR are my two favorites. I went beyond inspiration for this one, but I don't have confidence in designing for good solid furniture yet. I've had to abandon a project or two because of poor original designs and wanted a relatively sure thing with this one.
