junk731
- Sep 10, 2008
Christopher Robinson said:junk said:Christopher Robinson said:Jalvis said:Sliding table saws are an amazing tool for sheet goods or Solid timber. Its efficient and accurate. The real negative is the amount of space one needs to operate. I have a Felder 700 slider with 9' table and scoring blade. My saw allows for Dado blades as well.
Check out this video for the mother of all sliders, Martin T75!
Weird. Using the slider in conjunction with the rip fence on through cuts as shown in the 2nd video looks like a recipe for disaster...especially if they do that with hardwood...I mean with the slider virtually the only safety issue is kickback...and you have to be pretty dumb to initiate kickback...like using the slider and rip fence at same time...I digress someone correct me if Im.wrong here....
Its only weird to those that don't understand the operation, mechanics and setup of the slider. The slider when properly setup has the rip fence set with a .002 to .003 allowance from the leading edge to the trailing edge of the blade. The effect is you are only using the rip fence as a bump stop. There are a lot of subtle differences between a cabinet saw and a slider that most don't become aware until they have and use one.
John
That isnt enough to account for movement of wood when tensions are released during a through cut. MAYBE sheet goods wouldnt move from tension being released as much...but never for hardwoods...even with sheet goods... if the piece you are cutting isnt already in a perfect square with regards to the.edges.meeting both rip fence and slider fence... the rip fence could end up pushing the wood against the side of blade with enough force to cause kickback......am I the only one here that thinks that? Sheesh...wow...if that is true I'm amazed...
Why do you think Martin shows the method in their video, they are showing how to use these saws. These are not cabinet saws and there are cabinets shops all over the world that use this method on a daily basis for sheets goods. You do not use this method for ripping hardwood with its inherent instability. For hardwood ripping I oersonally work off the slider with 2 parallel guides and an air clamp or you can use the method Jalvis shows in his video.
John
