Smooth Table Top
bigfella
Hi Guys,
Just glued up a large (2700 x 1200) hardwood table top. The stock was a bit unstable and although it is reasonably flat, there are some high and low areas of around 2mm. Hard to see, but you can feel them.
What's the best way to sort this out?
Previously, I would have used a belt sander with a frame, but no longer have easy access to one of these. I do have a Rotex 150, but seem to be struggling to get it sorted with this. I am using the standard pad that was supplied with the Rotex. Should I be using a hard pad? Any tips before I run out and buy a BS75? ;-)
have you considered planing it by hand?  - lots of YouTube material out there showing how its done - cordless, no less  [smile]
Hans
Hi Bigfella,  You are on the right path using an RO150.  I used to long for a wide belt sander like a Supermax or the ultimate Timesaver.  That is until I got my RO150.  Get the hard pad and start with 80 grit and work your way up.  2mm is nothing to flatten.  The RO150 takes up zero floor space in the shop as well.
How about a BS105?
I am thinking of getting one myself... Maybe I should hire one out to you?
The plane is also a good option.
Jointer plane or router sled. Rotex and such do remove material quickly and make it smooth, but will not make 2700x1200 panel flat.
Finding someone with a Widebelt would be the best option, paying them would probably cost as much as the hard pad for the RO. If you just have high spot to remove and the top is generally flat then the blue pad on the RO would work like Jim suggested. If you have both high and low then a router sled might be an option but I would still recommend the widebelt for ease and cost.
John
Thanks guys. Might try a hard pad for the RO150. I know a shop that rents access to a wide belt, but they are closed for the holidays.
