I have embarked on a project of making some countertops for my dental practice. It is done with LG Hi-matics solid surface because of the color and price. I got the material out of Solidsurface.com. The seaming adhesive used is from Gluewarehouse.com. The Festools used are TEQ 55 saw with solid surface blade. This combination of saw and blade is probably the best thing for cutting solid surface and getting smooth cuts with no chip out and silky smooth cuts. I also was using Rotax 90 and 150 for sanding and finishing. I was also using 1400 router with various bits the one for doing the sink cut out was a CMT solid surface bit that has a nylon bearing and works well for cutting out the sink and not marking out the sink. It leaves a small overhang for a nice finish.
Clamping was done with 4" PVC solid core Sch 40 and 6" schedule 40 for the bigger clamps. If more tension is needed double up the clamps. I did one deck seam on the L-shaped piece. That was clamped with wood blocks hot glued to the surface and then clamped with 2 c clamps and one PVC clamp. The one pic shows the deck seam. Nothing fancy. Anyone had any questions feel free to ask. I am just learning as I go.
