Solid Surface is often known under a trade name from Dupont called Corian. There are many other brands that now manufacturer solid surface materials, in lots of colors and patterns.#Tee said:ahh thanks for clearing that up! i always wondered what solid surface was all about.
Remarkable stuff [big grin] All my counter tops at home are Corian, and my guest bathrooms floating vanity is a one off bent up Corian fixture. In fact so is the light fixture, that holds a recycled sea shell. The material can be heated and bent like the plastic it is, yet works very similar to wood. Better is it can be glued, and if done carefully the glue lines disappear. Repairs can be performed including cutting sections out and replacing them. Cleaning is easy enough. The material can be sanded to 500 grit, or mirror polished. It is a non permeable surface so good for doctors offices and food prep. The only bad thing is the material is expensive.
