jmbfestool
There are many Benefits to digital level and i do think its a tool to have in your kit but you dont need many different sizes the dont replace bubble levels.
600 to 1200mm will be go to sizes depending what you are thinking of using it most for.
Kitchens the 1000mm is ideal because most units are no wider than 1000mm and the depth of a unit 570+mm which still allows a 1000mm level not to tip off where as a 1200 will.
Dont buy cheap buy best one and just buy one.
If you went with 600 you could always use a longer level/straight edge to place the smaller digital level onto if needed.
Ive found them usefull for roofing easily setting or finding the roof bitch by simply placing level onto tiles or timbers or ceiling etc.
Fitting kitchens they have beepin sounds you can turn on.
So you can place level ontop of the unit and then get underneath and start turning the legs and just wait for the beeping sound. Saves having to keep coming back up to look.
