Tom the Remodeler
- Dec 30, 2007
Hi there gang! Wow, I just looked, it's been over 2.5 years since I last posted?!? Wow.....
Anyways, I've run into what I'm going to characterize as more of an "Issue" than a "Problem", but this seemed like the best place to post it.
I have a CT-Midi and a CT-26, previously I've owned a CT-36 (stolen in September) and a CT-22 (sold to make room for the CT-36). Something that I've been really underwhelmed about the Festool dust extractors is the power cords. Granted, yes, they're 25' long and heavy gauge, but the quality of the cord leaves much to be desired when used in the cold. They are simply too stiff to quickly roll and store in the Hose Garage when temperatures drop below 30 degrees, particularly when I compare them to my nice extension cords that are nice and supple down to below zero. To better fit in my van, I removed the rear cord hooks on my CT-26 and am currently storing the cord in the hose garage.
I am currently working on re-siding 5 townhouses with 4'x9' sheets of James Hardie. After we complete the town houses we will be residing ALL of the garages, which means another 1,250 sheets of Hardie. I am using my CT-26 to extract the dust as I cut the sheets. Based on the amount of work to do, I am going to be working on this job until the late Spring. So, that means all the rest of this Winter I will be trying to wind and unwind this stiff cord in potentially sub-zero temperatures. I've been doing this for three days and I'm sick to death of it already, and want to come up with a satisfactory solution.
So, I have two ideas, and would like some feedback.
Option 1: Pig Tail. Cut down my existing cord to roughly 12", just enough to tuck up into the garage, and simply store a 25' 12 gauge contractor-quality extension cord in the garage in lieu of the factory cord. Advantages that I see are I can potentially avoid opening the CT and messing around with the electrical internals. Also, disconnecting the extension cord might make it easier to wrap up? The biggest Con I see with this plan is someone might swipe the extension cord for another purpose, but I usually work alone and RARELY allow others to handle my tools, so not likely....
Option 2: Completely replace Festool cord with Contractor quality cord. This would involve opening the CT and completely replacing the cord. This might be nice to still have the whole works hard wired?....
Anyways, I would greatly appreciate any input you may have. Thanks and have a GREAT day!
Best,
Best,
