Very Nice, I have a couple of systainers I'm looking to do this too, thanks!
Has anyone used the Kaizen Foam in a similar fashion? Ive seen the foam used as like a tray for items and about 3-5 layers in a sys! I will try to find that pic.
Wonderful. I've been thinking of doing something similar, but not as cleverly. The system of slices for different tasks is brilliant. I never would have thought of it.
To tell you the truth, I made an elaborate Kaizen Foam insert for my Bosch 12V drill and impact driver, and ended up throwing the thing away. I ended up usinga SYS 1 Box that has all the little plastic containers with the foam top removed and a little piece of Kaizen Foam double-stick taped into the corner to keep everything in a little container I use for a few odd screws. (This one: Systainer with inserts) It's worked brilliantly for me.
I was kinda bummed, at first glance of your second pic I thought you figured out away to get four cold ones in a small space. Then I saw it was your chisels [unsure]. Still a great job! (even thought a brew or two would be nice.) B
