LaserGecko
- Jan 26, 2007
Here are a couple of photos of the new-to-our-shores Sys-Centrotec-Set, item # 493633 from Festool.
Availability is estimated at "late 2007" for "possibly around $260" but the rep was pretty sketchy on the last bit. It looks like it's available in the UK for ?170.21 which translates to ~$350 US right now. The vacuformed plastic felt like a heavier guage than the standard Systainer inserts, but I could be wrong.
An Aussie site describes it as: "A wide range of drill bits, screwdriver bits and adaptors contained in a Systainer case. The set comprises: 37 x Pozi bits 1 - 3, 20 x Philips bits 1 - 3, 40 x Torx bits 10 - 30, 8 x Centrotec spiral bits 3 - 6.5, 16 x Drill bits 3 - 6.5, 5 x Wood spiral bits 3 - 8, 3 x 100mm Pozi bits 1 - 3, 3 x 100mm Philips bits 1 - 3, 4 x 100mm Torx bits 15 - 30, 1 x Countersink, 1 x Bitholder, 1 x Magnetic bit holder, 1 x Hookdriver & 2 x Centrotec chucks"
DirectBrandTools says it includes the following:
Bit PZ1 - 7
Bit PZ2 - 27
Bit PZ3 - 3
Bit PH1 - 5
Bit PH2 - 10
Bit PH3 ? 5
Bit TX10 ? 5
Bit TX15 ? 10
Bit TX20 ? 10
Bit TX25 ? 10
Bit TX30 ? 5
Centrotec Spiral Drill Bit ? 3 ? 1
Centrotec Spiral Drill Bit ? 3,5 ? 1
Centrotec Spiral Drill Bit ? 4 ? 1
Centrotec Spiral Drill Bit ? 4,5 ? 1
Centrotec Spiral Drill Bit ? 5 - 1
Centrotec Spiral Drill Bit ?5,5 ? 1
Centrotec Spiral Drill Bit ? 6 ? 1
Centrotec Spiral Drill Bit ? 6,5 ? 1
Drill Bit ? 3 ? 2
Drill Bit ? 3,5 ? 2
Drill Bit ? 4 ? 2
Drill Bit ? 4,5 ? 2
Drill Bit ? 5 ? 2
Drill Bit ? 5,5 ? 2
Drill Bit ? 6 ? 2
Drill Bit ? 6,5 ? 2
Wood Spiral Drill Bit ? 3 ? 1
Wood Spiral Drill Bit ? 4 - 1
Wood Spiral Drill Bit ? 5 - 1
Wood Spiral Drill Bit ? 6 - 1
Wood Spiral Drill Bit ? 8 ? 1
Bit-Box PZ+BH60 CE - 1
Hook Driver 18 CE - 1
PZ1 long 100mm ? 1
PZ2 long 100mm ? 1
PZ3 long 100mm ? 1
PH1 long 100mm - 1
PH2 long 100mm - 1
PH3 long 100mm - 1
TX15 long 100mm ? 1
TX20 long 100mm ? 1
TX25 long 100mm ? 1
TX30 long 100mm ? 1
Countersink BSTA ? 3,5 CE ? 1
Long magnetic bit holder BV150CE ? 1
Bit holder BH 60 CE ? 1
WH-CE Centrotec ? 2
Bit PZ1 - 7
Bit PZ2 - 27
Bit PZ3 - 3
Bit PH1 - 5
Bit PH2 - 10
Bit PH3 ? 5
Bit TX10 ? 5
Bit TX15 ? 10
Bit TX20 ? 10
Bit TX25 ? 10
Bit TX30 ? 5
Drill Bit ? 3 ? 2
Drill Bit ? 3,5 ? 2
Drill Bit ? 4 ? 2
Drill Bit ? 4,5 ? 2
Drill Bit ? 5 ? 2
Drill Bit ? 5,5 ? 2
Drill Bit ? 6 ? 2
Drill Bit ? 6,5 ? 2
PZ1 long 100mm ? 1
PZ2 long 100mm ? 1
PZ3 long 100mm ? 1
PH1 long 100mm - 1
PH2 long 100mm - 1
PH3 long 100mm - 1
TX15 long 100mm ? 1
TX20 long 100mm ? 1
TX25 long 100mm ? 1
TX30 long 100mm ? 1
WH-CE Centrotec ? 2
