Sys-Midi Systainer on SysRoll?
briankb
I just got a new order in which included a Sys-MIDI systainer and a Sys-Roll transport.
I needed the Sys-Midi to hold some of my Woodpecker and other measuring tools and the Sys-Roll to tide me over until I could make the awesome MFT Tool Cart by TimTool.
I can not seem to get the MIDI to fit on the Sys-Roll, is it supposed to be able to fit?
I did notice and understand "Not compatible with Classic Systainers and Sortainers" but I did expect it to fit on the Sys-Roll.
The sys-roll is set up kind of like a classic sys as far as attaching things goes.  If you put a regular t-loc on the sys-roll first, then a midi-sys on top of that you should be good.
Hope this makes sense.
Ken
Brian,
Like Ken mentioned, the Sys-Roll cannot accept the SYS-MIDI as the bottom Systainer. But, it could stack on another Systainer. My apologies for the erroneous information on our website. The SYS-MIDI came out after the Sys-Roll and I failed to update it. I have now updated both products on the website to annotate the incompatibility.
If this is a problem, I can help you to work with your dealer to return it.
Sorry.
Shane
That may work, I'll give it a try later.
That's great you updated the US site so quickly!
It would be awesome if you could offer an "adapter" so the midi could be on the bottom.
We do offer an adapter. It's called SYS-1.  [big grin]
I just tried and even with a t-lock systainer on bottom and the Sys-MIDI on top of that it does not fit correctly on a Sys-Roll.
And there is no way that it could unless it is sitting above the rails uprights for handle. The systainer sits about 10mm inside the two rails.
Unless I'm missing something...
Brian,
Maybe a dealer can check it out first hand for us. I don't have a SYS-MIDI with me at the moment. If not, I can get back to you tomorrow more than likely with a definitive answer.
Shane
Ah... yeah. By rails you mean the uprights for the handle. I forgot the Systainers sit inside of that "L" shape. Well, I guess it won't work at all.  [sad]
Tom - Thanks for confirming!
Guess I'll look at getting a SYS 4 or 5 to hold those items and see if I can return the SYS-MIDI.
