Syslite question
EdL
While the Syslite is great if your working in a big area, I'm not. The room lighting is terrible too.
In this case its to dang bright.
Will a Syslite work with a dimmer?
Ed
I assume you mean the Syslite Duo?
The regular Syslite, which has an internal battery and can run with the BPC batteries, has two brightness settings and I have almost never found it to be too bright for any room or area.  The Syslite Duo, on the other hand, I thought I was going to get turned in to the authorities when I used it outdoors after sundown once...
Here is a good discussion about the concerns with attempting to dim an LED light like the Syslite Duo:
https://www.festoolownersgroup.com/festool-tool-reviews/syslite-duo-with-tripod/msg427377/#msg427377
Yes, the Duo.
Thanks for the link, doesn't look like anyone has tried it yet....
Ed
