SysRoll with Sys-MFT modification
Jasonfrantz
Hey folks, I've picked up a lot of ideas from this board, so I figured it's time to return the favor.
I've been a cabinetmaker professionally for 20+ years and use the SysRoll cart on a regular basis.  My only complaint was that in order to access the lower cases in the stack, I had to remove the cases above and inevitably ended up working out of open cases on the floor.  Not easy as I get older.  So I repurposed a Sys-MFT case with an extended top that serves as a shelf, allowing me to access three open cases at once.  Everything locks down and stable, just need to be careful to not overload a single side and off-balance the cart.  Pics attached for reference, and I hope this helps someone out there as much as it has me...
Great idea, I can see others, including me to take that idea and copy.
