Systainer MIDI perfectly accommodates MFS 400 and accessories
Minneapolis, MN
Well, the title pretty much speaks for itself!
I recently bought a MFS 400 template system, and, like the rest of my tools and accessories, I wanted to find a way to store and transport it in a protected manner that keeps it with all of its accessories, preferably in some manner of Systainer (I-V, MIDI or MAXI). Much to my delight, I found that the MFS 400, when arranged in a rectangle/picture frame shape, it fits perfectly in a Systainer MIDI. Width-wise, it just squeaks in, and for depth it rests on a diagonal, with the near edge resting on the bottom of the MIDI, with the far edge resting near the hinges. Underneath the MFS, there is plenty of room for the stock accessories, such as circle cutting parts, right angle brackets, and adjustment tool.
There is still plenty of room for additional parts and accessories, such as 400mm extension profiles and connectors (which allows you to further expand the size options available for the MFS), Imperial guide bushing sets, etc...
I am very pleased with this solution. With the MFS and its accessories stored together in a secure case, it fits well into my van organizational system, which means I'm more likely to take it with me on-site, rather than it being limited to shop-use. Longer term, if I can ever find time to organize things I'd like to make a plywood or Kaizen foam bottom to better organize the accessories, but for the time being I'm fine with them on the bottom.
I hope this helps folks, have a good one!
Best,
Great find! Looks like my next Systainer will be a midi. Like you I have not been comfortable with profiles and associate parts unprotected.
David
I think the MIDI Systainer would be a good addition for just this kinds of odd shaped longer length things, It will likely be something I'll look at in the future.. the MFS 400 also has my interest..
I have 11 of the Midis, they are great.  The Midi III's are a great replacement for Planos I used to use.  For tools that used the trays for accessories,I notched the sides so they fit right into the Midis. I keep all the following in Midis: a pair of grinders (a diamond & steel cutter), Bosch 6" sander, pair of lasers, Milwuakee M18v tools and batteries, misc chisels and pry bars, Milwaukee band sander, pair of electric die grinders, Milwaukee band file in one, Milwaukee mini bandsaw in another, Hitachi 3 5/8" jointer, and metal forming hand tools.
That's some seriously gear and quite a number of Sys Midi units! Festool need to make a Sys-Roll midi for transport..
