Systainer3 boxes or inserts?
nydesign
Hi, I bought a green Systainer3 to use as a first aid kit. One problem the T-LOC 1 box insert does not fit. I can maybe get the box portion to fit by cutting the insert, but the foam top is another issue. Are there boxes I missed for the new systainers? I see they have them for the M89.
Are you talking about the multi colored organizer boxes like what comes in the Box-Systainer I? https://systainer.store/collections/systainer-sets/products/box-systainer®-t-loc-i
I've not seen this for Systainer3.  Though I like the idea of having an insert for the Systainer3.
In the T-Loc assembly, it is the standard EPP Lid foam.  You can get one for the Systainer3 here: https://systainer.store/collections.../epp-foam-lid-insert-for-systainer3-systainer
One challenge might be if the boxes fit tight to the foam lid so that contents can't shake about.
Yes the multi colored ones, it looks like with some trimming the insert will work, the foam top you linked looks promising, thanks!
In the meantime I made a first aid kit out of an M89 systainer, it works great for that application. I like the slim size.
Cool - do post pics.  For the green unit too.  I really debated if I made SYS-Aid in red or green.  I went with red since it is more well known in the USA though, if I recall right, green is the international standard.
-Tim
I doubt Tanos will bring out a sys3 version of the box insert because they have the organisers. The organisers would probably make a better first aid kit too, as the transparent lid makes a lot of sense for something like that.
I like the organizer idea, thin profile, and transparent lid.  I'm am not so happy there is no top handle as it makes them integrate into a stack poorly for me so far.
A small gripe is that I wish they could have reused the boxes from the combi systainers/sorttainer; but I get that they couldn't.
