blairhalden
- Jan 28, 2012
Hello All!
After cutting four 3" holes my T18 has stopped working despite having a fully charged, healthy battery. It has been hours since it stopped. All it does is blink.
It seemed a little warm after cutting the first hole, so it got a rest in between holes. It only beeped a few times and only when it would catch on the material. The clutch was set to 25.
I have tried just about everything including the following: change battery; adjust every green dial, switch, button in every configuration I could think of; hold trigger while removing and replacing battery; and last but not least... hit it with open fist.
Do you have any suggestions? (Other than send it in of course)
Thank you for your time.
