Morris, your results are what I would have suspected. Impact drivers are a technological breakthrough in driving fasteners. There ratio of amp hours / driving foot lbs of force - is unmatched by any cordless drill.....even the BEST cordless drills in the world. Also as expected, the T18's tremendous feel for seating the screw is unsurpassed. However, asking the T15 to do the work of an I.Driver or a corded tool, is prob. asking too much from the tool. If your driving requirements were not so HEAVY (long lags / screws is surely a heavy load), the T15 would prob. be more than adequate to replace the I. Driver. From my experience with the CXS (I don't have such HEAVY driving requirements), I have found a mixed approach is best...for very small screws, the CXS does the entire driving. For larger screws, I let the I.Driver get'em almost seated, then fully seat them with the CXS....this assures they are seated without being stripped, something I. Drivers are notorious for. For those applications where the CXS does not have enough power to seat the screw its last 1/10th of length, I use 100% I.Driver. Of course, the T18 can do more than the CXS for sure. When the torque requirements surpass what a drill can handle, I try to size the torque requirements with an I.Driver with slightly more torque output. This is evidenced by the I. Driver driving speed slowing drastically when final screw seating is near, as when the last 1/10th of the seating is very slow, the risk of stripping the screw in the wood, or tearing its head off is very low. OTOH, when I use an over-sized I.Drive which has too much torque, its easy to strip the threads in the wood. I agree, lots of tools, fortunately the other brand names I. Drivers are not that costly. The I. Driver field is blessed with great products from low to high torque outputs. That's my take...
sl, I am curious how my you made the full leap from CXS to T18... I was considering the same move, but figured it might be overkill, since my driving Loads are not as extreme as Morris's requirements. I wish Festool had a Matrix of its drills, explaining or showing the benefits / drawbacks between the models. The T15 and the T18 do seem rather close in performance, weight, etc. What are the differences other than the obvious? Makes ya wonder why they have both?
