CXS: The Gateway Drill
BravoRomeo
First post to FOG! :-)
So I have all of you to thank for the dent in my wallet. My Panasonic EY6431 dill/driver is ready to move onto a nice, quiet retirement life. It put in many years of duty in projects around the house and woodworking shop. While it was top-of-the-line for its time, made in the USA, and cost a pretty penny (as I recall, somewhere around $500 including two batteries, charger, case, and a rarely used trim saw), it now needs new batteries and perhaps soon, a motor rebuild... it smells of toasted machine oil when run. With 3Ah 15.6V NiMH batteries and a 1/2" chuck, she's a beast. Not exactly a ballet dancer when it comes to finnese at the low and high ends of the speed controller, but it's been a brute, and it has the battle scars to tell stories of snaking drain pipes, drilling through old growth fir framing, building fences, etc.
At first, I thought I'd try a couple of those new-fangled LiIon drills, around the 10.8V range. First, for grins, was a Rockwell 3rill hybrid drill/driver/impact. Second, is a Festool CXS. Apart from the green accents, they are worlds apart, of course. The 3rill is an average Made-in-China branded uner a once-renowned name. It can drill small holes, drive screws, and has a switchable impact function on the gear selector (hmm, Festool should look at that for the TI15). In non-impact mode, the 3rill has less torque than the Festool CXS, despite the same voltage. Festool's motor and controller must be pretty special, even though the CXS is brushed DC.
The CXS... whoa! Here's a little drill/driver with great ambitions. It's still not quite a match for my Panasonic, but the CXS has a truly surprising amount of power coupled with real finesse and superb ergonomics. The extra chucks add real utility, and the Systainer is a pretty neat concept.
Still needing something more powerful for the rewiring project I'm working on, I picked up a brand new Festool C15 Li set from Woodcraft. Like the Panasonic, it was not inexpensive. Instead of a bundled trim saw, it includes some very useful chucks and starter bits. Now, we're talking! This drill has gobs of power, and just as much finesse, if not more, than the CXS. I'm amazed at the torque available at all speed ranges, largely due in part to that BLDC motor and controller. Quiet, strong, cool, and collected. I think I found my new drill.
Now, that little CXS is very nice, and I'd like to keep it, but I can see with having just the C15 as my go-to drill. It is surprisingly compact and lighter than the Panasonic. We'll see if I make use of both over the coming month, or gravitate towards one.
One thing lead to another, and now I have two Syslites as well. I gave up on halogens years ago, sparing just one 300W unit; otherwise my go-to trouble light has been a square compact fluorescent unit that plugs in. I supplement that with an LED headlamp. What I don't like about the fluorescent unit is the glare from the side and size... it's hard to aim the light so it isn't casting glare at you. The Syslites on the other hand are so darn compact and convenient - just grab and go. One is great for working inside a cabinet... having two allows setting up a shadow-free work area, or sharing with a helper (fighting over who gets the Syslite wastes valuable time!). Price may bother people on these, until you start looking at comparable solutions which give up one of: cordless, quality LEDs, robustness, or compactness. You'd have to manufacture these in China and use lesser quality LEDs to get them down to $100 or less, but that's not Festool, then. You get what you pay for holds true, yet again.
So... on with some test results.
Syslites, built-in battery, HI: 90 minutes, then 30 seconds of Low as a warning, then out
Syslites, built-in battery, LOW: 4 hours, then out
Syslites, 15V LiIon 3Ah pack, LOW: 10.5 hours, plus another 4 hours on built-in (great for emergency/camping use)
Drills... 1" self-feed auger bit through old growth fir, 3.5" thick. Admittedly a tough test, but one that is applicable to my current project.
Panasonic: all the way through, laboring just a bit as the battery winds down
Rockwell 3rill: gets about 1" into it and shuts off - just too much for it
Festool CXS: all the way through, but slowly and probably not happy about it (clearing compacted chips from the flutes helped)
Festool C15: all the way through, doesn't even break a sweat
The CXS is a clever "gateway drug" to the rest of the Festool lineup. It really hits a bunch of sweet spots all at once and probably could handle 70-80% of my missions. However, CXS really isn't up to regularly boring through this old house for wire runs (that it can do it in a pinch is impressive, though). There, the C15 is showing promise. In fact, I'd say the C15 was every bit as torquey as the "20V" LiIon Craftsman Pro we had the job. The latter is a huge brute of a drill, and sadly, discontinued. The owner says it is the best drill he ever had. Hope I can say as much, if not more, for the Festool.
So, thanks for all the analytical chit-chat, reviews, and videos here!
Thanks! Looks like a great forum, here.
A bit about me... my vocation is in software... avocations after that include probably too many things for hours in the day, but: piano, woodworking, old house projects, aviation, and photography. They all come and go in cycles. Time to flip the salmon burgers...
Welcome.  I love my CXS, I'm glad you're happy.  Everyone at work complains when they pick up my CXS: "it's too small for my hands!" to which I reply that they don't have to use it.  Fits my hands perfectly, I credibly light weight (before I owned an old 18v Dewalt and the thing was like lifting a dumbbell), and the compliment of chucks makes it able to get into some really tight places.
Just got my new C15 in the mail today, looking forward to putting it through its paces as it takes a trip wi me to work tomorrow.  I work in a yacht interior shop where sometimes th spritely CXS isn't powerful enough.  C15 should be a welcome addition.  Congrats on the similar acquisitions!
Glad you're happy with your purchase. I've still got a bit of life in my Panasonic EY6431 drill so I haven't had a force majeur reason to shop for a T/C/Ti drill from the Festool lineup, but after I bought my CXS last year for those 'nasty tight corners' I can't get into with the Panasonic I must admit that I think I've had to take out and recharge the Panasonic only once when I was doing some gate fixing in the backyard and had to screw in some 4" screws to hold the new hinges in place. Everything else the CXS has been able to cope with nicely.
It is very nimble and handy - if only the light would stay on for a few seconds {5-10s} after an initial push of the button because its way too easy to start the head rotating when trying to feather lightly pull the trigger to keep the light on to find that screw end in a dark place... And no, I don't have any syslites  [tongue]
I recently picked up both the CXS and a T12 drill kits as part of a trade deal.
Really liked the feel and size of the cxs, thought maybe it'd be ideal for cabinet installs, etc.  i ended up selling the cxs as it was just too close in capability to the T12, but quite a bit less powerful - enough so that it couldnt even be trusted to sink 2" screws at all.  Impeccable quality and build aside, it seems geared for less torque than other makes compact 10.8/12volt systems.
The T12 is the first Festool real drill Ive had, and I must say I'm impressed with it as a very capable system.  I do think it's rediculous that it doesnt have a belt clip or a light (slightly older LiIon model) as just about everyone else in the world has had clips and lights on their drills for over 5-6 years now....
I already had all of my tight access needs filled by my Makita LXT right angle impact and right angle drill, but to have everything in one drill body is pretty handy.
The whole Centrofix bit system is highly un-impressive in my view as theres quite a bit of play in it (suprisingly so), and it's a two step process to insert the bits (my makita impact is a push in and lock 1 step 1/4" QR chuck).
I thought the appeal of it was the tight toloerances and lack of run-out when compared to normal 1/4" insert bits and holders, but there doesnt seem to be any improvement over a quality made standard 1/4" bit extension.
Battery life and power are phenominal for a 12 volt drill, though it's quite a bit heavier, it's worlds ahead of the cxs in capability.
Just have to fabricate a belt hook for it to make a bit more usable in the real world.
Jt
