Roland Chung said:Brice,
Nice write up - keep going!
I have a PC router with an adapter from Bettersly that I use to trim edgebanding. It does a nice job, but you can only use a "V" type of bit and the bit seems to get gummed up with the adhesive from the edgebanding. I'm considering upgrading if only for the superior dust collection.
Do you need to use a special (expensive) Festool bit to trim edgebanding and is there any reason to believe that the adhesive on the edgebanding will not gum up the bit in the same way that the "V" shaped bit gets gummed up?
Thanks,
Roland
tvgordon said:Brice,
I had a chance to see the MFK 700 this weekend. I placed the motor in the horizontal base, and unless you have a really short bit, I don't see how it would work for trimming dowels flush.
Tom.
greg mann said:Brice,
I checked it out. The vertical orientation in the 1.5 deg base is 1.5 off vertical.
Michael Kellough said:1. what is the purpose of the 1.5 degree tilt
2. what kind of bit do you use?
3. are there any US designed router that do this, if so which?
4. or, do we just use special bits in a different way in NA?
Brice Burrell said:Michael, the 1.5 degree horizontal base tilts the base 15. off the centerline of the bit, this produces a very slight chamfer. The purpose this to prevent cutting into the horizontal surface when edge trimming. Here's a model, veneer plywood with edge banding, the bit is held at 1.5 degree (exaggerated angle in the model) to prevent cutting the face veneer.
No special bit needed and I don't know of any other router that does this.
monte said:just checked,
The French (Virutex) does make a 1.5 degree cant on its trim router (& adjustable up).......http://www.virutex.com/Tiltable_Trimmer.html
monte
ps. hmmm, a sense a comparitive Festool MFK 700 / Virutex FR292R review in the future.![]()
Brice Burrell said:Roland Chung said:Brice,
Thanks,
Roland
Roland, pretty much any edge trimming bit will work in the MFK, so no, you don't have to use a "special" Festool bit. Unfortunately, when trimming edge banding the adhesive "gum up" is always an issue.
monte
Woodenfish said:Did you notice that model you referenced has a 5/16" collet only?
The MFK 700 has a 1/4" plus an 8mm collet included which seems like a more useful tool.
Eiji Fuller said:Brice,
I am interested in the 0 deg. horizontal base. Will you be reviewing that as well? Is there room in the systainer for it? it looks a lil tight.
The 0 deg base is needed if you apply your veneer after edge banding. It would also be useful in trimming edge banding around an outside corner since with the 1.5 deg base the bit height would be too high to cut the banding flush as you go around the corner.
Eiji
