bnaboatbuilder said:I don't own a Kapex but here are two vendors online who carry Tenryu blades for the Kapex. I have purchased from both companies with success. Using Tenyu Kapex or Tenryu 260mm 30mm as search terms narrows down to what will fit the Kapex.http://www.carbideprocessors.com/search.php?search_query=tenryu+260mm+30mmhttps://www.fastoolnow.com/iw-26080ab.html
The two links posted above are for two different Tenryu 80 tooth blades for the Kapex, the MP-26080AB and IW-26080AB. The first is the standard Miter Pro Plus blade they have produced for years and it is made in Japan. According to Tenryu, the second is a newer, less expensive industrial series blade that is made in China with the same tooth count, but a slightly different tooth grind, rake, and kerf. Has anyone tried the new style or both styles of this blade on their Kapex?
Thanks, Mike A.
