Hi ,this is my first post so go easy on me. I was wondering if any or you have used a Through Domino for a design element, and if you did, did you dip the dominos in dye, stain or india ink for contrast ?
Yes, I have used a through domino for "domidrawers." There is a thread on the FOG about it with some photos of my drawers and others'.
I don't think I stained the dominos but I could be wrong. It was several years ago. Since the exposed dominos are end-grain it absorbs more finish anyway and stands out by itself.
I would suggest you try it first on some scrap wood of same dimensions. I recall reading depending on the depth of plunge and the bit, the surface slot might be sleeping gurly elongated...... Solution is not to plunge as deep.....
I built an outdoor planter box for my wife last year and thought it would be fun to try them. I used the sipo dominoes which are already reddish in color.
I used a through Domino today to connect an oak leg post and apron together with Sipo tenons. I used my DF700 Domino joiner with a 10mm cutter to cut 2 3/4" tenons. I have to admit that this was a repair job on a desk but the tenon went in real smooth and the contrasting wood looks good. This is not an exposed joint but if it was I would fill in the gaps (around the domino tenon) with West Systems Penetrating Epoxy.
I've used exposed sipo dominoes in cherry to lengthen the glue line joining rails to stiles for some Shaker-style cabinet doors I made a couple of years ago. My customer didn't understand the concept at first, so I make a mock-up to educate her. Last time I spoke with her, she really loved the contrast with the finished doors in place.
I have used the DF 700 to create "wedged thru" tenons for a design feature. Here are photos of a sofa table that I built for someone. The third photo is harder to see, but the top is held on with with the same wedged thru tenon as the leg braces are.
I assume that, if you really wanted the through tenons to look more traditional through tenons it would be possible to cut the domino a little short, chisel the corners square at the exposed part of the tenon, and make some custom plugs out of whatever wood you desired; then glue these plugs in. Or does that sound impossible?
Another option that I have used is to use my DF700 to cut the mortises, square them with a chisel and use an integrated tenon cut on the thru rail which I wedge in place.
Here's a picture of a thru joint in Black Walnut with maple wedges made with my Domino joiner and chisel.
