Birdhunter
- Jun 16, 2012
I need an adaptor for my TID 18 that allows use of the Festool bits and drivers. I see a couple of bit holders on the Festool USA site, but it doesn't say what they actually do.
Birdhunter said:I need an adaptor for my TID 18 that allows use of the Festool bits and drivers. I see a couple of bit holders on the Festool USA site, but it doesn't say what they actually do.
MrToolJunkie said:Try these options. They have worked well for me.
https://www.festoolusa.com/accessory/204384---bt-imp-sort4#Overview
https://www.festoolusa.com/accessory/204382---bt-imp-sort2
The Centrotec bits do not work, because the are not impact rated. It’s a feature.Birdhunter said:Yes, the Centrotec bits do not work in the TID18. Normal bits do work. I have a ton of the Centrotec bits and want to use them.
Birdhunter said:I just got back from Highland Woodworking with the Sort4 kit. It does fit the TID18 and accepts Centrotec bits. The kit includes impact bits. Thanks everyone.
Rick Herrick said:Looks like you solved your issue but wanted to make sure you knew you could use centrotec bits in your T18 with the regular centrotec chuck and the adaptor.
Thank you [member=11629]GarryMartin[/member]. I didn't know about the difference.GarryMartin said:That won't work. He's asking about the TID 18 not the T18.
Euclid said:There is an fairly short adapter called 'BA-CE' which has a hex shank (which can be gripped in Jacobs chuck), and a fitting to accept a Centrotec chuck. Not the most elegant solution for a TID, but would that help?
GarryMartin said:It's the one listed above by part number by [member=72312]Rick Herrick[/member], but the hex shaft isn't 1/4" so it won't fit into the TID 18. The Wiha 7148C is the way to go if you want to use Centrotec bits in a driver with a 1/4" hex connection like the TID 18.
